Daggle Posted December 22, 2006 Report Posted December 22, 2006 Hopefully with my xmas presents I will be stripping out the interior and putting in my Cobras with the harness'
Doc Posted December 22, 2006 Report Posted December 22, 2006 Finish the prefect now its been welded up J
Col-ashtonmobile Posted December 22, 2006 Report Posted December 22, 2006 well in between work , the old mk1 v6 is having the engine taken out for a repaint on the engine bay , then engine is having new cam & head work in the quest for more power Want me to come and paint it for you Colin sounds great , your very welcome
totti Posted December 31, 2006 Report Posted December 31, 2006 HOI! Take the 2,8 EFI Engine from 86s Scorpio into my Taunus MK1....lot of Work over Chrismas! Greet Totti
Mk 1 Mark Posted January 2, 2007 Report Posted January 2, 2007 Things to do......... 1:Fit new Complete floorpans 2:Fit new Gearbox tunnel 3:Paint the inside/underside of the car 4:Fit new All Steel XE engine 5:Fit new 45mm Throttle bodies 6:Run new Engine loom and Omex ECU 7:Fit new alloy Fuel Tank (fiesta Steve let us know when mate ) 8:Run new Fuel/Return Lines 9:Fit New 4 pot Willwood Calipers 10 Run new Brake lines 11:Get car running again and Set up.. 12..Drive like a mad man and show all the new plastic cars what its all about!! 13<<<<<<<<<<<<< Bring It On in 2007>>>>>>>>>>>>>>>>>> 14<<<<<<<<<<<<< Mad for it YFKT >>>>>>>>>>>>>>>>>
Retromotorsport Posted January 4, 2007 Report Posted January 4, 2007 the plans where ... Fit a charge cooler to one car .... done Fit front suspension to mk2 Duratec racer .. not done .(parts) fit passenger side door bars ....done fit seat ... sorta done fit O/H console for switches and pull cables ..done make holes through the bulkheads for fuel and oil ..done make steering column and fit ..not done (..need driver) Fit prime cage to the mk1 i'm building .. done have some time off .. sorta done
