trevb Posted July 13, 2009 Report Posted July 13, 2009 Ive got 2.8 capri front legs on the escy, and i need to replace the front drivers side hub and bearings, not really bothered if its new or not (the hub, not the bearings that is) or i'd even consider buying the whole front leg, if the price is right. If anyone can help that would be great, as im getting a nasty wobble under braking and i need to fix it asap. Cheers, Trev.
caprinerd Posted July 14, 2009 Report Posted July 14, 2009 try caprisport or any of the companies in cf and rf that ad in them
vibrating_Cake Posted July 14, 2009 Report Posted July 14, 2009 i have one somewhere I THINK ill look tomorrow night
jamesg Posted July 15, 2009 Report Posted July 15, 2009 try CapriGear, very good prices and has always had the parts im after (in the back of CF and RF)
4parajon Posted July 15, 2009 Report Posted July 15, 2009 Dont see why you have to replace the actual hub itself?? Unless you've been driving it for a while with the bearing fooked and its actually damaged the hub itself........but I can't see that myself
trevb Posted July 16, 2009 Author Report Posted July 16, 2009 Well it started when my bro had the car and he smacked a kurb and knackered the front wheel, TCA, and anti roll bar, so ive replaced the lot, even a new streering rack and coupling joint, brake master cylinder, and disks and pads, and im still getting a nasty vibration under braking. The caliper seems fine, so i can only think that the hub itself has been bent or the caliper is not sitting straight with the disks (but i think the latter will only cause uneven wear on the pads)? Any help would be great as im at my wits end with it. Cheers, T.
vibrating_Cake Posted July 16, 2009 Report Posted July 16, 2009 i had same problem with one of my old hubs, thus why i should have a spare somewhere, looking tonight for you dude . hit it wrong and bent it, still got a slightly buckled one on the capper to this day, nothing much to worry about thouhg
4parajon Posted July 16, 2009 Report Posted July 16, 2009 hairymuff mate, if Mr Cake can't find one i suggest you log onto capripower as someone on there is bound to have one for you
vibrating_Cake Posted July 17, 2009 Report Posted July 17, 2009 crap sorry i forgot to look while i was down! shall look for you asap though! just remembered now, been a busy week!
Slammed Posted July 17, 2009 Report Posted July 17, 2009 try tickover in bexleyheath they can sort you out
trevb Posted July 18, 2009 Author Report Posted July 18, 2009 cheers for that link, they only seem to have uprated ally ones at £70 a pop, but ill give them a call on monday to double check. and no worries about forgetting to check, i dont get paid till the end of the week so ive got till then before i can spend any more momey. Cheers for the help!
vibrating_Cake Posted July 18, 2009 Report Posted July 18, 2009 got no hubs sorry, just got hubs machined for my 283mm disks
