a neighbour has asked me to fix his childs motorbike. they assembled the kit themselves (with no instructions), but the suspension is VERY stiff. almost solid. i only had a quick check over it but was wondering if any one knew what the issue was?
i will post the bikes specs later...
thanks very much.
Engine: 125CC Single Cylinder, Air Cooled, 4 Stroke
Drive System: Manual clutch with chain tensioner / guard & heavy duty chain
Gearbox: 4 Speed
Ignition: Electronic
Starter: Electric and kick start
Brakes: Front and Rear Disk brakes with Braided hoses
Wheels: Powder coated coloured rims
Tyre: 14 Inch front, 12 inch rear off road tyres
Rear Suspension: Heavy duty swing arm & rear hydraulic shock
Front Suspension: Heavy duty front forks and headstock
Power: Wheelies in 2nd and 3rd gear!!
Features: K&N style air filter, Billet style fuel cap & Engine sump guard
Speed: Up to 55MPH
Exhaust: Deep sound performance exhaust – sounds awesome!
Max Rider Weight: 16 Stone (100 Kg)
Dimensions:
Handlebar Height 41 inches (104 cm)
Handlebar Width 30 inches (76 cm)
Seat Height 30 inches (76 cm)
Overall Length 5 Feet (152 cm)
Fuel: Unleaded petrol
Accessories Incl: Tool Kit and Manual
Colours: Red or Black
Combined Postage Deal: Order 2 or 3 bikes and pay only £60 for delivery!!
is the shock adjustable,does it have a small screw at the top & botom,for bump & rebound as the may be set on max & is the spring wound tight on max as all these factors can give a very hard feel :mrgreen:
