pauln Posted September 6, 2009 Report Posted September 6, 2009 Thought I would smarten up my Cortina starting with refurbing the doors (drivers front done and ready to go on). I decided to do the rears at the same time but since I rarely carry rear passengers I thought I would take off the rear handles and weld up the holes (have seen this on another Mk2 Cortina and I like it). Will the MOT man throw a fit and fail the car?? Any MOT experts with an opinion?
V8ian Posted September 6, 2009 Report Posted September 6, 2009 He should not throw you out for that, but there has to be at least 1 door that is capable of being opened from the outside, which IIRC my mates hotrod had no door handles, the doors are opened using a small motor on the lock, with a spring in the jamb, push the button and the door pops open, but if you look under the sill there is a pull cable attached to the opening mechanism which constitutes as an external method of entry,
pauln Posted September 6, 2009 Author Report Posted September 6, 2009 Thanks Ian, I can always keep the old doors in reserve anyway, think i will just do it.
Tom Posted September 6, 2009 Report Posted September 6, 2009 No, all doors must open from the outside for an MoT
pauln Posted September 6, 2009 Author Report Posted September 6, 2009 All right I won't do it (I should have done this as a poll). What a shame (I preferred Ians answer).
Copey Posted September 6, 2009 Report Posted September 6, 2009 fit poppers and hide a release switch linked up to all the doors?
stevie.t Posted September 6, 2009 Report Posted September 6, 2009 if you realy want to remove the handles you can, you will need to hang wire/string from the inside handle so the door can be opened from out side, open the window and leave the wire on he out side, the car can then be opened from the outside, you remove after its mot,d,the mot man can pass or pass and advise either way it will pass
pauln Posted September 6, 2009 Author Report Posted September 6, 2009 Thanks for the replies. I can live without doing it, in some ways I was just looking for a job to brush up on my welding and filling skills. I will just find something else to do (saying that I could use that spare central locking solenoid via an external button to trip the latch and push the door open.......................nah).
pauln Posted September 6, 2009 Author Report Posted September 6, 2009 http://www.motuk.co.uk/manual_620.htm Oh sod it, just when I had given up that suggests that the rear doors only have to close securely but the front ones have to open and close from outside. Decisions, Decisions. Thanks for the info .
emu Posted September 6, 2009 Report Posted September 6, 2009 http://www.motuk.co.uk/manual_620.htm Oh sod it, just when I had given up that suggests that the rear doors only have to close securely but the front ones have to open and close from outside. Decisions, Decisions. Thanks for the info . Thats how I read it too. Pass and advise I reckon
