CapperTom Posted September 7, 2009 Report Posted September 7, 2009 Hi, This winter i shall be putting a 2.1 pinto in my capper with stage 2/3 head but i have a choice of carbs, at the mo its got 45s on it but i have just got a pair of 48s that need rebuilding cheap but not sure if in the long run its worth doing and just keep the 45s and sell the overs. I want max power obviously but i want to keep driveabilty as its being used on road with ocasional blasts etc. What are your thoughts Many thanks Tom
Andrade Posted September 7, 2009 Report Posted September 7, 2009 I guess you will have to relate these to the cam & bhp you are estimating to have?
Andrade Posted September 7, 2009 Report Posted September 7, 2009 You might to give this a look too. It suggests using 45s on a 2.3 litre http://www.revingtontr.com/shop/downloa ... 20size.pdf
SmokeEm Posted September 7, 2009 Report Posted September 7, 2009 48's aren't normally needed unless well over 185bhp
Andrade Posted September 7, 2009 Report Posted September 7, 2009 48's aren't normally needed unless well over 185bhp I have also come across zetecs with 200bhp and over using 45s too
escort new boy Posted September 7, 2009 Report Posted September 7, 2009 ive seen 220bhp pintos running 45s
Fiesta Steve Posted September 7, 2009 Report Posted September 7, 2009 You might get big power from your 45's but they probably have large chokes ie 40mm, a choke that size in a 45mm body won't have great drivability, the same size choke may work better in a larger body such as a 48 to give a greater venturi effect for maximum drivability
