Andrade Posted September 14, 2009 Report Posted September 14, 2009 Hi guys, can anyone tell me whats the shortest length escort adjustable TCAs go to from xmember hole to the balljoint? I am considering buying escort adjustable tcas to pull the weel in the wheel arch of my anglia, but im afraid i'll end up buying a pair and not have enough setting to decrease the length as much as i want to.
samurai Posted September 14, 2009 Report Posted September 14, 2009 If you really want to bring in the whole lot youd need adjustable top mounts to
Andrade Posted September 14, 2009 Author Report Posted September 14, 2009 yes i already have the eccentric top mounts, thanks i did not know they dont go any shorter.. i'l have to get these custom made then.
Wessie Posted September 14, 2009 Report Posted September 14, 2009 if your building the front suspension from different bits then have you considered moving the mounting points on the crossmember?
Andrade Posted September 15, 2009 Author Report Posted September 15, 2009 I have thought about it but it is not suggested. I still cannot totally understand why but i dont want to risk it either.
Ken B Posted September 15, 2009 Report Posted September 15, 2009 Cos if your TCA mounting points are not in the correct location compared to the steering arm pivot joints then you can get bump steer.
Andrade Posted September 15, 2009 Author Report Posted September 15, 2009 Cos if your TCA mounting points are not in the correct location compared to the steering arm pivot joints then you can get bump steer. Ah ok! so I guess i will have to custom make something like this?
Ken B Posted September 15, 2009 Report Posted September 15, 2009 Steering geometry can get quite complicated. Here is an explantion of bump steer from a magazine I had years ago from my race days. You should be able to read it. though its primarily for race cars with double wishbone, it obviously can apply to road cars on struts too. Figure 1 is the pic you need to look at mainly.
Andrade Posted September 15, 2009 Author Report Posted September 15, 2009 Thanks a lot for the article! I'll print it out and read it cos it sounds like what i need. Thanks!
Andrade Posted September 16, 2009 Author Report Posted September 16, 2009 I get how bumpsteer is caused now, thanks a lot for the article! I couldnt get it at first becasue i was not considering the up and down movement of the suspension Now the problem is.. how can i make the TCA shorter without risking to ruin it? Any help in this is greatly appreciates as it is the next on my to-do list. I came accross these from Rally Design. Possible winners? http://www.rallydesign.co.uk/product_in ... ts_id=7194
RUSTYPUP Posted September 16, 2009 Report Posted September 16, 2009 The length of the TCAs needs to be the same as the distance between the outer track rod end and the pivot on the rack.
Ken B Posted September 16, 2009 Report Posted September 16, 2009 The length of the TCAs needs to be the same as the distance between the outer track rod end and the pivot on the rack. Well yea but that is set when you do the tracking isn't it. ie if you have adj TCA's if you lengthen it to give more camber, you would have to adjust the steering arm length as well or you will end up with toe out or toe in if you adjust them inwards. The critical points are in the diagram i posted up, are that of the TCA chassis mounting point and the pivot point of rack steering arm in the straight ahead position. Which is why you shouldn't really move the mounting point as Wessie is suggesting unless you gonna alter the rack as well.
Andrade Posted September 16, 2009 Author Report Posted September 16, 2009 I do not wish to fook up the steering as im basically building the car to go as fast as i can in corners i asked a few sellers on ebay the length from balljoint to rosejoint and they all said 250mm, which is practically the same length as a standard tca. however one of them said they can make it a bit shorter if i'm willing to add a small fee. i need approx 1" less, would be nice to have it 2" shorter then i can increase a bit as necessary just in case. dont know if its possible, wil mail him tomorrow
Ken B Posted September 16, 2009 Report Posted September 16, 2009 Well i'm presuming you've already pulled the top in with eccentric top mounts, is it really sticking out at the bottom that much? Others have used the Escort setup so they must use something off the shelf unless they've all altered their own TCA's.
Andrade Posted September 16, 2009 Author Report Posted September 16, 2009 yes theyre pulled in as much as possible from the top mounts.. but i still need at least 1" to clear the wheel arch :\ i have 13x6 wheels on the front thats why im asking maybe theres someone who went through this already and can propose something from someone?
samurai Posted September 16, 2009 Report Posted September 16, 2009 Wont most people tube frame the front end to do this sort of moding...
Retromotorsport Posted September 16, 2009 Report Posted September 16, 2009 The length of the TCAs needs to be the same as the distance between the outer track rod end and the pivot on the rack. Well yea but that is set when you do the tracking isn't it. ie if you have adj TCA's if you lengthen it to give more camber, you would have to adjust the steering arm length as well or you will end up with toe out or toe in if you adjust them inwards. The critical points are in the diagram i posted up, are that of the TCA chassis mounting point and the pivot point of rack steering arm in the straight ahead position. Which is why you shouldn't really move the mounting point as Wessie is suggesting unless you gonna alter the rack as well. Bit sweeping that statement, especially as the suspension in the diagram is upper and lower wishbone, and without me drawing out that steering system ... i'm sure having a leading rack will give adverse ackerman.. if it was trailing, opposite to the drawing, you would have ackerman. On old fords ackerman was created by having the outer TRE further forward than the inner ball joints on the rack. The important measurments are ... the difference in height between outer pick ups must be copied on inner pickups... the difference (if any) between the outer pickups from the cars center line have to be copied on the inners. ie if you have angle steering arms to get ackerman, you have to have the same angle at the inners.. so yes, TCA and Track Arm have to be the same length on a single TCA/Wishbone setup twin wishbones are totally different .. as that twice as many calculations
steve dray Posted September 17, 2009 Report Posted September 17, 2009 I have had a similar problem with mine. For some reason before I bought my car the strut tops had been moved in, ie closer together than normal. At the time it had an escort crossmember and shortened anglia tca's. I wanted to change the tca's to escort one's but when I fitted standard length escort tca's I had massive negative camber! which was great for the handling but not very practical long term. So I did similar research to what you are doing now and I finally stumbled across a company called 'Compbrake Ltd' (search for them in the web) they made me some escort adjustable tca's which were 30mm shorter than standard so I could get the camber to something sensible. They were very helpful and I think they only charged me an extra £10 to make them shorter. Hope that helps
Andrade Posted September 19, 2009 Author Report Posted September 19, 2009 I have had a similar problem with mine. For some reason before I bought my car the strut tops had been moved in, ie closer together than normal. At the time it had an escort crossmember and shortened anglia tca's. I wanted to change the tca's to escort one's but when I fitted standard length escort tca's I had massive negative camber! which was great for the handling but not very practical long term. So I did similar research to what you are doing now and I finally stumbled across a company called 'Compbrake Ltd' (search for them in the web) they made me some escort adjustable tca's which were 30mm shorter than standard so I could get the camber to something sensible. They were very helpful and I think they only charged me an extra £10 to make them shorter. Hope that helps thank you steve that was very helpful! i will check them out i appreciate
