Badgerman85 Posted October 21, 2009 Report Posted October 21, 2009 so for a while my car occasionally pops and misfires and splutters when going round sharpish corners...but now it just completely cuts out, like literally just stalls, happened about 3 times while i was driving around town, go to turn a corner and pffft she just stalls.... any ideas??
4-Door Pete Posted October 21, 2009 Report Posted October 21, 2009 Hi, sounds like fuel starvation. Are you running an electric fuel pump?
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 yea its a leccy fuel pump, why would it be cutting out on corners though? and its like pretty much brand new, only been in the car for about 5000 miles??
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 What one is it sometimes they cant keep up with cornering
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 its a facet silver top competition one
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 well sounds like fuel starvation you running twin carbs???
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 was set to 2.5psi last time it went up to W.P.E shall i try turning it up a bit?
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 well are you running twin carbs?
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 Well i would re check the presssure of what is pumping
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 i am indeed, 40 dcoe's... ive heard so many people suggest so many different pressures for them though?
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 if you cant get it sorted give us a ring 02086696092, we will come and sort it
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 if you cant get it sorted give us a ring 02086696092, we will come and sort it as awesome as it would be to be lazy and get you guys to come sort it i'm far far to broke to even consider it as an option
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 if you cant get it sorted give us a ring 02086696092, we will come and sort it as awesome as it would be to be lazy and get you guys to come sort it i'm far far to broke to even consider it as an option Not much more i can suggest pal, we are very well priced especially on old ford motors, ask on here mate , but you have a fuelling prob
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 what pressure should i be running?
4-Door Pete Posted October 21, 2009 Report Posted October 21, 2009 I think the pressure should be 4psi. I have a weber tuning book at home I'll double check and let you know.
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 I think the pressure should be 4psi. I have a weber tuning book at home I'll double check and let you know. cheers mate!
Joe-ashtonmobile Posted October 21, 2009 Report Posted October 21, 2009 put 4 psi through it, and by by carbs they will wash away
SmokeEm Posted October 21, 2009 Report Posted October 21, 2009 It should be 2.5psi Mike Check the connections etc, might be damp, loose etc
Badgerman85 Posted October 21, 2009 Author Report Posted October 21, 2009 could it be an ignition problem?
