Just a quick question :gary: . What is the ideal running oil pressure on a 1600c xflow, once warmed up (idling and under load). As mine went through the floor :dope: . Sol i've changed the oil pump but dont know what psi i should be looking for..... :think:
Once warm, the xflow in my Anglia runs at 40psi under load and then drops to around 10-20psi at idle.
Hope that helps!
Cheers Jamie :thumbsup:
Looks like it was the oil pump that had gone up the wall :( Only reading 12 psi underload :eeek:
But new one is now fitted and running at 33 psi underload and 20 psi at idle :D Job sorted :cheers2:
