I'm trying with little sucess to fit a 711 block xflow where there was once a 681 in a mk2 cortina, but how ever hard I try It wont go between the crossmember, I'm using the original mounts and just asumed a 1600xflow is a 1600xflow, do these fit or do I need new mounts or make some form of modification?
Very sorry mods if its in the wrong section but need a quick answer only got tonite to get it sorted before they ship me away again :(
anyone come across this before?
I seem to recall reading somewhere that because the 711 block has thicker walls than a 681 so that the block engine mounts a slightly wider and you have modify the engine mount to make it fit :thumbsup:
if its like a 1600 escort mount they will unscrew off the mount.
but if not the heat from welding would cause it to prob fall off..
