mk1mexico Posted November 8, 2009 Report Posted November 8, 2009 Iv had help from guys on here before so i thought i would ask your advice. Basically got a leak sprung from the end of a rubber hose connecting two copper pipes within my Vaillant Boiler Enclosure. Its fitted with a sort of 'one use' clip that looks like its been crimped, similar to some modern day car radiator pipes, so it will need to be cut off and replaced with something else. Im confident a decent jubilee clip will hold it or will it??? In any case i need so guidance as to how i drain down the boiler before starting any work. Thanks in advance for any help Could get some pictures up tonight if its going to be any help, but i can fix it myself if i have the information on how to drain down the boiler so i dont get an early shower
chrisd Posted November 8, 2009 Report Posted November 8, 2009 Hi mate you can get away with just draining the boiler not the whole system turn all the valves off under the boiler and locate the pressure relief valve should have a red nob that is spring loaded or a little black lever mounted on a red cap turn the nob or pull the lever to release the pressure and yes a jubilee clip will work hope this helps chris from radgas
BIGKEV Posted November 8, 2009 Report Posted November 8, 2009 have a search on youtube - surprising what you can find on there!!
Copey Posted November 8, 2009 Report Posted November 8, 2009 Hi mate you can get away with just draining the boiler not the whole system turn all the valves off under the boiler and locate the pressure relief valve should have a red nob that is spring loaded or a little black lever mounted on a red cap turn the nob or pull the lever to release the pressure and yes a jubilee clip will work hope this helps chris from radgas just asked my dad (he's been a heating engineer since he was 16 and he is now 53) and he says the same thing
marky4 Posted November 8, 2009 Report Posted November 8, 2009 Hi mate you can get away with just draining the boiler not the whole system turn all the valves off under the boiler and locate the pressure relief valve should have a red nob that is spring loaded or a little black lever mounted on a red cap turn the nob or pull the lever to release the pressure and yes a jubilee clip will work hope this helps chris from radgas agree, but make sure you refit the casing properly (agood seal) or it might be dangerous
mk1mexico Posted November 8, 2009 Author Report Posted November 8, 2009 Thanks for the tips people, i have just got home from work, tools in hand, but going to wait until tomorrow, as im off work, and will have time to correct any fook ups Will the boiler not just fill itself up as i empty it? Or will it be ok as it will be switched off? Bear with me im a novice
marky4 Posted November 8, 2009 Report Posted November 8, 2009 Thanks for the tips people, i have just got home from work, tools in hand, but going to wait until tomorrow, as im off work, and will have time to correct any fook ups Will the boiler not just fill itself up as i empty it? Or will it be ok as it will be switched off? Bear with me im a novice on the flow and return pipes where they come out of the bottom of the boiler they should have some valves on them (usually ball-o-fix type you need a screw driver to turn them off, a quarter turn) then you will just have the water that is in the boiler which you can dump out with the pressure relief valve as already said. hope this helps mate
mk1mexico Posted November 9, 2009 Author Report Posted November 9, 2009 Yes iv got this bit straight forward in my head, its just it says on a sticker on the front of the boiler its not to be drained, as its got an anti rust additive in it
marky4 Posted November 9, 2009 Report Posted November 9, 2009 Yes iv got this bit straight forward in my head, its just it says on a sticker on the front of the boiler its not to be drained, as its got an anti rust additive in it the additive will be in the hole system so what you loose out of the boiler is niether here nor there
mk1mexico Posted November 10, 2009 Author Report Posted November 10, 2009 I bottled it Got the Mrs' Plumber uncle coming round to sort it sometime this week Cheers for your help though, to be honest if i were single i would have cracked on and done it, but im not allowed now
