mr shag Posted December 5, 2009 Report Posted December 5, 2009 i have compleatly stripped down the bottom end of my pinto for a good clean up etc im putting the same pistons and rings back in what i would like to know is do i need to glaze bust the bores or not any advice would be much appreciated thanks
Toby Posted December 5, 2009 Report Posted December 5, 2009 I would recommend you take the whole lot to a friendly engine conditioners - you should fit new rings anyway, so ask them how much they will charge to measure the bores, pistons and, if it's all within acceptable tolerances they can give the bores a light hone. It wont cost much and will give a fresh finish for the rings to bed into. You can just buy a de-glazing tool but they do leave a smoother finish than a real hone. The coarser honed finish helps hold the oil for the piston. The tool will probably cost about the same as a hone by a pro.
