hi all at the moment i have 8in drum brakes on the rear of the escort. i have been offerd a 2.8 capri set up drums back plates the lot. either way im going to need to rebuild either set up which would be best and why? anyone else used this set up on an english axle any problems? :thumbsup:
I had capri 9 inch once drums and fitted them and the wheel would not go round :mrgreen:
I guess you need wheel spacers between the half shaft and the inside of the drum cover.
If your buying id go for disc set up...i wish i did after rebuilding my mexico drums brakes which cost abit..abit more money and i would have had a nice disk set up.
I have 2 Mk1 Escorts with 2.8 drums on the back. One has Laser alloys on it, the other has steel Wellers, both are 13" rims and have no fitting issues whatsoever. I can only think you didn't have the right backplates if the wheels wouldn't go round.
The handbrake linking bar across the axle will need shortening if you fit the 2.8 drums. The backplates go in a long way so are closer together when fitted.
As for whether they are better brakes, I can't honestly tell.
