Exact engineering in Totnes devon, they also do the stuff with a clear plastic coating over it by the metre, guys there really know there stuff and really helpful, even do mail order and lots cheaper than goodridge
By the metre?,
I beleive MOT/construction regs wise, you cant use home made braded lines, they are meant to be crimped ends rather than screw together ends, I have loctited all my ends as I assembled the lines, I have never been questioned about them either,
If you intend running a a full length from front to back, its advisable not to, the piping is designed not to expand diametrically but it does expand over its length, so the longer the runs, the more of a problem this becomes with soft pedals, m not making this bit up, I was told by the owner of Think Automotive, the man who sells more of the stuff than anybody else,
THe only reason I could find out about the type of fitting is they can come undone and the hose pull out.
