evil knievel Posted March 14, 2010 Report Posted March 14, 2010 Im looking to put an XE in my Capri But am just curious of cost and power output? It will be a daily driver so I don't want excessive power, but I still want a little bit of OOOMPH! So whats involved? I have read the thread in the Engine Transplant room but would just like some idea of the cost... Discuss
Yeomans22 Posted March 14, 2010 Report Posted March 14, 2010 i looked into this, and cost of parts alone was over £2000, if you can get second hand stuff it stil wont be cheap.
livewire7116 Posted March 14, 2010 Report Posted March 14, 2010 biggest expense is an ECU system however you can use a manta dizzy with a bracket to mounted to side running it off the ex cam. SAFCapri done a Xe install in his Capri and by time he sold off all his pinto stuff he reckons it cost him about £500. Not a bad outlay for an extra 50hp minimum over his stock pinto on 40s. Have look in the resto section, it sits nicely in the bay and has plenty of room
Tom Posted March 14, 2010 Report Posted March 14, 2010 I used a MegaJolt system for the sparks mate and i got it all running for less than £200
livewire7116 Posted March 14, 2010 Report Posted March 14, 2010 if i remember right when we done SAFs capri there was loads of room on the sump from the xmember so you may even be able to use a std alloy astra sump, but then again if you chassis mount you can put it pretty much anywhere
