cortinasgoneforaburton Posted June 23, 2010 Report Posted June 23, 2010 Hi all i posted a problem a while ago about my cortinas brakes the pedal going to the floor not pumping up but the pedal getting some pressure after a while. The advise off you guys was the master cylinder. It failed its mot on brakes it needed all new flexi hoses so to sum up its had new calipers and pads last year new flexi pipes for new mot new master cylinder replacment servo (wider fiment type) new brake fluid, pedal still going to floor and not pumping up. Even put a heat shield over brake pipes as they are near 4 branch manifold any ideas people
bortaf Posted June 23, 2010 Report Posted June 23, 2010 rear brake shoes well out of adjustemnt ?? that will give a long pedal travel but it will come up if the hand brake is on and the pedal is pumped a few times ? If you've fitted another servo check the rod isn't very slack between the pedal and servo, also check the rears are bled porpperly they can be a pain to bleed.
