Jiffer Posted July 29, 2010 Report Posted July 29, 2010 I have had a fair bit of grief from the 40s I have fitted to my mk1 cortina. tonight I got the last few bits done to the wirering to the fuel pump (facet silver top ) it has a filter king regulator on it and when I powered up the pump to set the pressure (which I have set at just under 3psi) I get a steady stream of petrol out of one of the carbs is this just a set up problem or should I be looking deeper? cheers
Col-ashtonmobile Posted July 29, 2010 Report Posted July 29, 2010 where abouts is it coming from the trumpets ?
Jiffer Posted July 29, 2010 Author Report Posted July 29, 2010 yes mate, it poors out of both the trumpets on the rear carb
