your regular battery will be fine - its the cable you need to beef up- i'm using some heavy duty welder earth cable , not cheap but well up to the job- my battery is a 1.0 corsa one and has never even hinted at not coping
i had my battery in the boot running the v8, but allways turning over slow..two much drain on the cable...battery now sit's behind the drivers seat and changed the cable to a very fine wire ( not sure what type ) around 13mm thick...start's on the button first time now.....ended up cutting out around 8' of cable...... :thumbsup::thumbsup:
Here's a pic of the cable I used when I moved my battery to the boot. I got it from Thames Valley Electro Diesel. It's probably overkill, but didn't want cable over heating and melting under the carpet.
thanks peeps some good advice :thumbsup:
I used 20mm cable as they say that any thing thinner you lose voltage to the starter all so make sure the engine is earthed well
