I have had corsa power steering fitted to my Anglia , was made for me by Matt Downer you will find him on turbosport his user name is cossie matt . His kits are absoutley spot on and very well enginereed can not reccomend him enough :thumbsup:
I think you mean the electronic power steering Colum that the Corsa c runs. Not to sure how you will go about it as they have a mini ecu that takes on the speed your traveling at so it can determing how light to make the steering.
The kit Matt Downer does comes with an adjustable switch and a control box that takes care off all the electrical side of the unit just adjust the steering to how light you like the steering with the adjustable switch and away you go .
Matt uses a Corsa C unit and make sure it is also a non adjustable one , he has done loads of kits for different cars and can supply all the brackets you will need to fit it
i will concour with ian,matts kits are excellent i have had 3 of his on my escorts and all excellent.i had one of his on a mates xe mini as well and it was fantastic and traansformed the shit torque steer it used to have
