Savvi Posted February 22, 2011 Report Posted February 22, 2011 Wondering if anyone has used a normal rev counter (mk2 tina one) on a crossflow with a electronic ignition kit fitted ?
samurai Posted February 22, 2011 Report Posted February 22, 2011 Wondering if anyone has used a normal rev counter (mk2 tina one) on a crossflow with a electronic ignition kit fitted ? You would have to get the rev counter converted. Speedy cables charge i think about 70 pounds to do it. I need to get mine done soon, its annoying when things dont work properly
Savvi Posted February 22, 2011 Author Report Posted February 22, 2011 Is that the case with all electronic ignition systems ?
samurai Posted February 22, 2011 Report Posted February 22, 2011 Is that the case with all electronic ignition systems ? If your using old rev counters then yes 70 pounds well spent tho once done
Admin Vista Posted February 23, 2011 Admin Report Posted February 23, 2011 Is that the case with all electronic ignition systems ? If your using old rev counters then yes 70 pounds well spent tho once done No it isn't. It depends what sort of electronic ignition system you're using. Perhaps with really modern systems that do away with the coil then yes it's true but with older electronic systems like lumenition it'll work just fine
Mad Mex Posted February 23, 2011 Report Posted February 23, 2011 my rev counter worked fine when i installed a bestek kit to my crossflow.
Savvi Posted February 23, 2011 Author Report Posted February 23, 2011 It has lumenition fitted so it should still work ok then ? I tried to do some reading up on it and it seemed some worked others didn't So i should be able to just wire in the rev counter with the loop into the coil feed as normal without setting his car on fire Thanks All
Admin Vista Posted February 23, 2011 Admin Report Posted February 23, 2011 It has lumenition fitted so it should still work ok then ? I tried to do some reading up on it and it seemed some worked others didn't So i should be able to just wire in the rev counter with the loop into the coil feed as normal without setting his car on fire Thanks All Yep, that's exactly how mine is set up with a Lumenition Optronic system.
samurai Posted February 23, 2011 Report Posted February 23, 2011 I have bestek kit and my rev counter does not work and mr bestek said its because i have electronic ignition system so the rev counter wont work. I didnt know there are different types of electronic ignition systems
Mad Mex Posted February 23, 2011 Report Posted February 23, 2011 I have bestek kit and my rev counter does not work and mr bestek said its because i have electronic ignition system so the rev counter wont work. I didnt know there are different types of electronic ignition systems maybe coz i have a mk2?...he told me it may or may not work when i bought the kit of him, i wired it up and it was fine so left it
samurai Posted February 23, 2011 Report Posted February 23, 2011 I have bestek kit and my rev counter does not work and mr bestek said its because i have electronic ignition system so the rev counter wont work. I didnt know there are different types of electronic ignition systems maybe coz i have a mk2?...he told me it may or may not work when i bought the kit of him, i wired it up and it was fine so left it Lucky..i have to pay more
rallyesport04 Posted February 23, 2011 Report Posted February 23, 2011 i had a bestek in my old mk1 escort an wouldnt work with the dash rev counter either
lotusless Posted February 23, 2011 Report Posted February 23, 2011 i had a bestek in my old mk1 escort an wouldnt work with the dash rev counter either i had a bestek on a mk2 cortina before + could not get it working must be an "old" car thing
rallyesport04 Posted February 23, 2011 Report Posted February 23, 2011 i had speedy cables convert it to electronic worked a treat after that
w p e Posted February 23, 2011 Report Posted February 23, 2011 early r/counters work through a coil pulse wire so should work fine. ive fitted a few dozen of johns kits with no probs along with luminition
Tom Posted February 23, 2011 Report Posted February 23, 2011 Mine's running straight off a ford EDIS unit and works fine
