brettp Posted May 11, 2011 Report Posted May 11, 2011 took the car to at speed dyno today went in running 270 came out 320 nitrous test didnt go to plan but all safe and afr readings spot on well worth a look if in essex car runs the nuts but the clutch release bearing suffered might be the 4th gear wheel spin or the 150 mph in 5th learnt a lot difference in the car is night and day just need to save up and sort out clutch dyno was money well spent there number is 01268773377
KJ 1320 Posted May 11, 2011 Report Posted May 11, 2011 took the car to at speed dyno today went in running 270 came out 320 nitrous test didnt go to plan but all safe and afr readings spot on well worth a look if in essex car runs the nuts but the clutch release bearing suffered might be the 4th gear wheel spin or the 150 mph in 5th learnt a lot difference in the car is night and day just need to save up and sort out clutch dyno was money well spent there number is 01268773377 Nice one mate
