GJUK Posted January 23, 2012 Report Posted January 23, 2012 Hi, I have this. and this I've recently ordered a copy of classic ford with a fature section on wiring up electronic ignitions to a car. Firstly do the parts I have shown enable me to get this to 'work'? I'm not sure if the coil or dizzy are the right type... Has anyone else done this mod, perhaps written a step by step guide? Please help. Need to get my car sorted. Thanks, Jon
GJUK Posted January 23, 2012 Author Report Posted January 23, 2012 Bit of research and this is the coil http://www.burtonpower.com/0221122450.html Thanks, Jon
Jiffer Posted January 23, 2012 Report Posted January 23, 2012 this is what I think, the coil should be fine as long as its 12v, from the module plug, thin black rubbery wire not needed, green negative to coil, black positive to coil, brown earth to body, the other two go to the dizzy, remeber to earth the dizzy. all you need is you positive ignition wire to the positive side of coil.
GJUK Posted January 23, 2012 Author Report Posted January 23, 2012 Easy! Where do I find my possitive ignition wire? Thanks for your help. Jon
Jiffer Posted January 23, 2012 Report Posted January 23, 2012 a nice 12v supply coming from the ignition, if possible find the old one or wire in a new one
GJUK Posted January 23, 2012 Author Report Posted January 23, 2012 a nice 12v supply coming from the ignition, if possible find the old one or wire in a new one does it have 'nice 12v supply' written on the cable to make it easy for me?
Jiffer Posted January 23, 2012 Report Posted January 23, 2012 a multi meter will tell you that mate, just as long as its not a permanent supply, coils dont like that.
