As title, got a mk2 RS2000 and after a 2 piece prop as i cant be doing with the vibration of my single piece any longer.
Preferbly in good condition so i can just bolt it on.
Cheers Dale
I had my single piece prop rebuilt as a cush drive prop. A tube within a tube with a rubber sleeve between the two but if your prop is vibrating that badly, it may be out of balance. A single piece prop can transmit diff noise into the gearbox but they don't usually transmit much b vibration into the car unless they're either too long or they're out of balance.
I had 2 new uj's put in it and balanced twice each time the vibration has changed at different speeds. This time though its around 75 - 85 which is really annoying on the motorway.
Yep I had some vibration issues with my van when I first completed it, they drove me mental . I had the original solid prop built by these people, who then converted it to a cush drive prop in my quest for quieter running. Probably worth a call to them to explain the issue you're having and see what they think. I assume you're certain it's the prop causing it and not something else? I have a single piece solid prop on my mk1 RS2 and don't have any issues
http://www.davemacprops.com/DMPHOME.html
They made the original single piece solid prop and were recommended to me by Fostek who built the axle for me. I then decided I wanted the original converted and sent it back to them, the prop was fine both times (vibration was caused by the gearbox mount) but I was looking for as many ways as possible to quieten it down inside.
