seaneylad Posted December 1, 2014 Report Posted December 1, 2014 Diameter is 252/253mm... Which is the sticking point. Can't find any? Been told they could m3 discs machined down etc Completely lost at the moment haha Capri discs are 245mm? I'm running princess caliper's not with the big spacer kit just the washer spacer kit Any advice or help anyone? Thanks
Admin Vista Posted December 1, 2014 Admin Report Posted December 1, 2014 Rally design used to do a disc specially for the Princess caliper conversion, you'll need to space the calipers out to use it though. Otherwise a standard 2.8i capri disc will do it (but will still need the caliper spacing)
seaneylad Posted December 1, 2014 Author Report Posted December 1, 2014 Rally design used to do a disc specially for the Princess caliper conversion, you'll need to space the calipers out to use it though. Otherwise a standard 2.8i capri disc will do it (but will still need the caliper spacing)Thanks Currently got it spaced using the washer spacer kit Not the propa spacer kit you see online. Don't think there would be space its tight as it is Would I be best with the Capri ones then not the ones from rally design ? Thanks
Admin Vista Posted December 1, 2014 Admin Report Posted December 1, 2014 Thanks Currently got it spaced using the washer spacer kit Not the propa spacer kit you see online. Don't think there would be space its tight as it is Would I be best with the Capri ones then not the ones from rally design ? Thanks I'm not sure what you mean by the washer spacer kit, are you talking about the washers that go between the caliper and the leg? That's not the same spacer. The spacer I'm talking about goes between the two halves of the caliper to make them wide enough for vented discs. If you're already using vented discs then you probably already have spaced calipers This is the spacer kit that goes between the two caliper halves http://www.ebay.co.uk/itm/PRINCESS-CALIPER-SPACER-KIT-/260945980685?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item3cc197ad0d And this is the spacer kit that goes between the leg and caliper http://www.ebay.co.uk/itm/CALIPER-SPACER-WASHERS-M16-PRINCESS-MK1-MK2-MK3-FORD-CAPRI-ESCORT-CORTINA-RS2000-/201224664516?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ed9ecb5c4 And this is the 257mm Rally Design disc, but you do also need the spacer kit between the two caliper halves to use them (if you're not already using vented discs) http://www.rallydesign.co.uk/product_info.php?products_id=13564
seaneylad Posted December 1, 2014 Author Report Posted December 1, 2014 I'm not sure what you mean by the washer spacer kit, are you talking about the washers that go between the caliper and the leg? That's not the same spacer. The spacer I'm talking about goes between the two halves of the caliper to make them wide enough for vented discs. If you're already using vented discs then you probably already have spaced calipers This is the spacer kit that goes between the two caliper halves http://www.ebay.co.uk/itm/PRINCESS-CALIPER-SPACER-KIT-/260945980685?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item3cc197ad0d And this is the spacer kit that goes between the leg and caliper http://www.ebay.co.uk/itm/CALIPER-SPACER-WASHERS-M16-PRINCESS-MK1-MK2-MK3-FORD-CAPRI-ESCORT-CORTINA-RS2000-/201224664516?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ed9ecb5c4 And this is the 257mm Rally Design disc, but you do also need the spacer kit between the two caliper halves to use them (if you're not already using vented discs) http://www.rallydesign.co.uk/product_info.php?products_id=13564 Thanks for the time and reply with links, appreciate the help Here are mine on the car for a while back haven't taken a closer look Can you tell these have the spacer kit on?
Admin Vista Posted December 1, 2014 Admin Report Posted December 1, 2014 Yes they do, look between the two caliper halves and you can see an insert piece. If you follow an imginary line straight down from the bottom inside edge of the disc, that's your caliper spacer. The RD discs are 257mm and should be fine between those
seaneylad Posted December 1, 2014 Author Report Posted December 1, 2014 Yes they do, look between the two caliper halves and you can see an insert piece. If you follow an imginary line straight down from the bottom inside edge of the disc, that's your caliper spacer. The RD discs are 257mm and should be fine between those Ah cool .. Thanks for the info Got all the bits to get the calipers rebuilt so I'll get the discs and all good to go then. Abother question answered on OSF maybe one day I'll be able to help someone haha instead of asking all the questions
Admin Vista Posted December 1, 2014 Admin Report Posted December 1, 2014 Ah cool .. Thanks for the info Got all the bits to get the calipers rebuilt so I'll get the discs and all good to go then. Abother question answered on OSF maybe one day I'll be able to help someone haha instead of asking all the questions Order yourself a calendar by way of thanks and you'll get something nice to hang on the wall for your trouble too http://www.oldskoolford.co.uk/ipb/index.php?/store/product/34-2015-old-skool-ford-calendar/ 1
