Just do a search for Welding Cable , you wont go far wrong with that.
Biggest issue is voltage drop because of the long leads. Bigger wire means less resistance, hence less voltage drop.
I used to use a big ol' leisure battery in the boot when i was running a mega high compression pinto, but you should be fine.
If the battery is goosed, by all means, get a larger one, but if you don't need to spend hard earned then happy days!!!!!
Mk1 Escort under bonnet battery trays are tucked into a recess in the front nearside corner, you can make it a little longer (if you don't have side draughts on it) but making it wider isn't really an option.
Just ordering the bits now,
Is it work having a 250amp fuse close to battery im boot? Read that somehwere
if not im just going to use the cut off that Vista mentioned earlier :)
Thanks
I've been wondering about doing that. My everyday car is a Jaguar XJ8 and that has a big fuse on the battery. It seems a good idea.
Yeah people say it's not needed. Can't seem any harm in a mega fuse and mega fuse holder with a decent fuse in?
Not sure if I will or not yet haha
