crapichris Posted February 19, 2007 Report Posted February 19, 2007 had a bit of a scare returning from Ace Cafe on Saturday Oil pressure dropped down lower than 'normal', the faster I went the lower it got! Managed to get home ok. Strange as tonight I went out and started the car and the pressure is up to 'normal'. I will change the oil and filter at the weekend as a matter of course but don't thnink it's either of those. 2 ideas come to mind - either the pressure relief valve is stuck or the oil pump is saying goodbye. If it is the pump is it an engine out joobie or can I get to it from the front of the engine? It looks like I can - any experiences or ideas chaps and ladies?
Noodles Posted February 19, 2007 Report Posted February 19, 2007 The pump sits at the front of the sump inside so unless you can get the sump off whiles its in the car its gotta come out
crapichris Posted February 20, 2007 Author Report Posted February 20, 2007 something strange going on here! Been out today and pressure is up again although a bit sluggish at getting up to pressure. Could it be a sticky pressure relief valve and would flushing oil help?
Jay_harrier Posted February 20, 2007 Report Posted February 20, 2007 Easier options are to check the pressure sender & gauge, it's strange behaviour but you'd be pissed off if you'd got covered in oil & it was those at fault. To do the pump you have to pick the lesser of two evils, lift the engine out or high enough to drop the sump, or drop the cross member. I'd probably opt for the latter & support the engine across the stut tops with a bit of 4x2. It can be hassle having to seperate the track control arms, steering knuckle though. I can't remember with the capri if you can get enough height by lifting it off the engine mounts to pull the pan out - it'll probably be the oil pickup thats the snag. Exhaust & bellhousing limit the movement too. Actually it might be the strainer on the oil pickup that's partially blocked, I'd still do the pump if you're taking it apart. You could always opt to do a pre-season inspection/freshen up ready for the good weather.
crapichris Posted February 20, 2007 Author Report Posted February 20, 2007 thanks for the ideas. Problem I have is that the engine ain't meant to be in a MK1 pre-facelift so everything is tight. I agree that it may be an engine out. I still think it might be the pressure problem (hence my thoughts about the relief valve) not a gauge, as there is a slight rattle just before the pressure rises. Also if you disconnect the HT lead and spin her over on the starteruntil the pressure comes up on the gauge then reconnect the HT and start her the problem doesn't arise. Also once she is up and running she'll go all day without a hitch.
jayson2.3pinto Posted February 20, 2007 Report Posted February 20, 2007 if you have a rattlei would say that you have worn bearings m8 if your pump is on the way out and is not pumping this will almost finish off your bearings so i would say engine out and inspect pump and big ends and main bearings for sign of wear when you flush out the old oil get it warm and when the oil is drained check for any particals ie metal fragments hope this helps
crapichris Posted February 20, 2007 Author Report Posted February 20, 2007 mate thinks the pressure relief valve on the pinto is a ball bearing with an interference fit. He thinks this might be what is rattling as it sticks.
