GJUK Posted March 28, 2016 Report Posted March 28, 2016 Hi guys, I need to replace some rubber hose (which was bought as supporting brake fluid) that are sweating brake fluid :-/ This wil lbe the 2nd time I have had to replace these pipes, they are not under pressure, simply fitter to two barbed fittings for the bias brake pedal box res to the box. Can anyone suggest where I can get 10-12mm ID rubber type flexible pipe which I can use for these push on fittings. eBay does not appear to be listing anything that supports brake fluid. Thanks, J
colr6 Posted March 28, 2016 Report Posted March 28, 2016 Are you sure on the ID measurement, think the ones I've used are 8mm ID if 8mm is any good I have some surplus mayby a metre let me know. Just a quick check it'll be 3/8 just under 10mm 1
GJUK Posted March 28, 2016 Author Report Posted March 28, 2016 Hi thanks. The hose on there is 10mm ID. Happy to buy some expensive hose, just not able to find any
colr6 Posted March 28, 2016 Report Posted March 28, 2016 Got some from rally design, been on maybe 5 years still ok.
colr6 Posted March 28, 2016 Report Posted March 28, 2016 You could always use the PTFE lined braided hosing
colr6 Posted March 28, 2016 Report Posted March 28, 2016 Sure is, goodridge and the likes are PTFE lined.
