bradderz Posted April 22, 2016 Report Posted April 22, 2016 I've finally decide that I'm goin to stick a set of bike carbs on the escort but I don't know what the best option is for fueling them. Is a bike fuel pump better or is it better to run a facet silver top with a pressure regulator any help would be appreciated an if anyone is running bike carbs on a crossflow what set up have you got many thanks brad
NudgerSS Posted April 22, 2016 Report Posted April 22, 2016 Just use the bike pump. I've put one on mine in preparation for using bike carbs but just running it through the Weber for now Sent from my iPad using Tapatalk 1
DT36 Posted April 23, 2016 Report Posted April 23, 2016 Agreed with above. I'm using Fireblade Carbs and also use an electric bike pump, close to and below the tank. 1
NudgerSS Posted April 23, 2016 Report Posted April 23, 2016 Yes as close to and below the tank as you can get it Sent from my iPad using Tapatalk 1
GJUK Posted April 25, 2016 Report Posted April 25, 2016 ticker bike pump here, they stop 'ticking' when floats are full. Running a 200bhp pinto, no problem fueling it. 2
NudgerSS Posted April 27, 2016 Report Posted April 27, 2016 Yes mine ticks away when I turn ignition on but gradually stops Sent from my iPad using Tapatalk 1
