fiestachaser Posted June 10, 2016 Report Posted June 10, 2016 Hi, Finally going to "Bite the bullet" and Zetec my Mk1 Cortina. It was Classic Ford Show which did it! Too many Zetec and ST170 conversions. I'm looking for basically all parts-nice lump,sump,type 9,mounts etc. Please let me know if you have any parts or a complete kit. Thanks Stuart
colr6 Posted June 10, 2016 Report Posted June 10, 2016 I'll have a couple of type 9s kicking about Stuart. 1
robert maguire Posted June 11, 2016 Report Posted June 11, 2016 I used Tiger Sports cars for the alloy bell housing /flywheel,starter motor and other bits.G19 engineering for sump /modification.Dan ST for manifold and carbs if neccessary. I used Retro for mounts/alt bracket/gearbox adjustable mount and few other bits but quality is very poor.I am sad to say I could not recommend Retro to anybody.If you do use Retro get the wide tunnel gearbox mount ,not standard, even for standard tunnel. The "standard" mount is way too narrow and fits badly.I had to widen mine by approix 4inches even though its standard Ford manual tunnel GRP4 alloy rad and Spal fan.Custom made exhaust.Check out my posts under Blacktop to escort mk2 conversion recently 1
fiestachaser Posted June 12, 2016 Author Report Posted June 12, 2016 Thanks Robert, Some useful info.
jackbarnes60 Posted June 14, 2016 Report Posted June 14, 2016 hi Robert, i see you based in Essex, i have just recently finished a Zetec conversion and i am really pleased with the outcome, i have my setup built by Quest Motorsport in Rochford Essex, two guys down there father and son really helpful and know there stuff with Zetecs! give them a shout mate they can pretty much answer any question you are likely to have with the conversion Jack
fiestachaser Posted June 24, 2016 Author Report Posted June 24, 2016 Bump! still on the look out for the above conversion parts.
65cortina Posted November 12, 2016 Report Posted November 12, 2016 hi mate im just about to start the same project as you, im going for the st170 engine and plan to keep the vvt even with a bike carb conversion and a nodiz type sparks arrangement. i had a chat with dan st engineering and he said by the end of november he will have a module that will control fueling,sparks and vvt and be fully mappable. i going down the 4 speed gearbox route, hopefullly a bullet box with that long bottom gear, keep us posted on how you get on and please if your going 5 speed type 9 box and you are offered a bullet or even a rocket 4 speed let me know. im in essex and have a large van to collect stuff, if its all in the same place i can collect for you too. thanks russ.
