HotRodMatt Posted June 29, 2017 Report Posted June 29, 2017 Hi Katana , what i did forget to say the new fillercap was also bad , but what we think is that the thermostat went to late open. The engine did warm up in a normal time period. And yes it can be true what you say about the engine did not run inefficient , becourse later when we did place the dubble valve springs , than came out that the fourth cylinder did leak , and what we find out that the headbolts did miss the washers or is it normal that the pinto doesn`t have the washers ? So now have ordered a set at ARP . The Pinto doesn't have head bolt washers, at least not for the later stretch Torx bolts. 1
John escort mk1V6 Posted June 29, 2017 Report Posted June 29, 2017 Hi Matt thanks , i didn`t know that anymore , it`s been some 8 years ago when i rebuild it and i did not forget some parts , the bolts are the non stretch Multi tooth one`s. 1
DT36 Posted June 30, 2017 Report Posted June 30, 2017 I've recently fitted a Pinto head with Reinz head bolts. There were no washers on these and none under the bolts I took out.
John escort mk1V6 Posted June 30, 2017 Report Posted June 30, 2017 Hi dt36 , there is not much space for a wide washer , the bolthead is pretty big for the hole a small washer is possible. 1
