oldwheels Posted November 1, 2021 Report Posted November 1, 2021 1980 MK2 ESCORT 4 DOOR This Escort is another S.A. import and comes with Nova Certificate This is an ideal opportunity to purchase a very easy to finish project with all the hard work carried out and most of the expense dealt with. The shell has had all work necessary carried out to a good standard and is now 100% solid requiring no further welding, with a lot of effort being put in. Being a S.A. car it comes with RS strengthing kit fitted. Spare wheel well, chassis, floors. sills, top plates, doors, wings, arches, door pillars, all solid as stated New front and rear screen rubbers Long Range fuel tank, fuel pipe changed side to suit pinto. Engine low mileage 2.0 Pinto 205 block, proper engine mounts and steel sump, 4-2-1 wrapped exhaust manifold, engine complete with all ancillaries. Type E gearbox mounted on alloy blocks, quick shift kit included, gearbox tunnel has been nicely modified not beaten to death. Front suspension, RS Struts, RS track rod ends, 145 -2" new springs, 2.8i vented discs and callipers, Double width kit, fully polybushed, Rear suspension std, but comes with new 145lb single leaf springs, GAZ Adjustable shock absorbers and 2" lowering kit. Also with the car is, Round light Grille Oval strut brace Fibre glass rear boot spoiler Pair of Corbeau S/H seats Escort seat runners Two RS Alloys. All trim pieces switch panel etc is with the car. Car needs an Exhaust system, prop shaft, Radiator, and a few odds. The car is in Cornwall and will need a trailer to take away. £6,250 1
oldwheels Posted November 15, 2021 Author Report Posted November 15, 2021 Well no interest, it is in a dry garage may have to revisit in the Spring,
Brenda1978 Posted January 3, 2022 Report Posted January 3, 2022 Still for sale. Couple of guys looking for one
