Admin Vista Posted July 9 Admin Report Posted July 9 Old Skool Ford Classic EP GL4 80 Gear Oil Use code OSF01 at checkout for 10% discount Product Details Old Skool Ford Classic EP GL4 80 Gear Oil is an extreme pressure additive treated monograde gear oil based on heavy grade quality base oils and additives. Old Skool Ford Classic EP GL4 80 Gear Oil is a premium lubricant specially formulated for classic and vintage vehicles. This extreme pressure (EP) gear oil provides superior protection, ensuring smooth operation and extended life for gears in certain classic transmissions. Old Skool Ford Classic EP GL4 80 Gear Oil the preferred choice for classic and vintage vehicle enthusiasts seeking a high-performance gear lubricant. With its extreme pressure protection, viscosity stability, and corrosion resistance, Qualube ensures the longevity and reliability of gear systems in classic vehicles, preserving the authenticity and performance of cherished classics. Suitable for gearboxes and transmissions where an additive based fluid is required. Commonly used in applications where a lighter SAE 80 grade lubricant is required to provide good boundary lubricant. Benefits Extreme Pressure Protection: The EP 80 formulation offers exceptional extreme pressure protection, preventing wear and damage to gears under high load conditions. Viscosity Stability: Old Skool Ford Classic EP GL4 80 Gear Oil maintains stable viscosity across a wide range of temperatures. This ensures consistent lubrication and protection, even in varying climate conditions, providing reliable performance in both hot and cold environments. Oxidation Resistance: The gear oil is fortified with antioxidants to resist oxidation and thermal degradation, promoting long oil life and maintaining the oil's performance over extended periods of use. Corrosion and Rust Protection: Old Skool Ford Classic EP GL4 80 Gear Oil includes corrosion and rust inhibitors to protect gear surfaces and internal components from the harmful effects of moisture, ensuring prolonged gear life. Seal Compatibility: Formulated to be compatible with a variety of seals and gaskets commonly found in classic vehicle gear systems, reducing the risk of leaks and ensuring effective lubrication. Meets the following performance levels: API GL-4.
