Get a new rev counter..... :lol: ...if its the same sort as a mk2 tina the ignition wiring goes through the rev counter...if the rev counters damaged or disconnected the car won't run..found out the hard way :x . They have a wire wrapped round a coil on the inside of the counter and this picks up pulses from the coil, i have found wiggling that wire makes it work again... :mrgreen:
I know that, but its is a new one (new old :lol: ) but i think it just need adjusting
will have a fiddle with the screw :thumbsup:
I wouldnt touch that screw as thats there for calibration.. you have probably got a leaky capacitor inside the rev counter. Dosent matter if it is NOS as there dry up over time and crack.. seen a few like this.. worth a look..
Last time i played with the screw it worked, so i will again if it doesnt work i will have to get another :roll::lol:
If the capacitors leaky can i fix it??? :D
Could be...there was a place that would put electronic stuff inside the older casings for more reliable gauges...can't remember who did it now though :?
Im interested :mrgreen:
