Hi, the fuel gauge is only reading half even though we put 31 litres in the tank last night.
We took the sender out the tank and manually moved it up and down, and the gauge went to full so whats wrong???????
We tried putting an eart wire on but didnt make any difference!
:thumbsup:
Sounds like something is stopping it going all the way up inside the tank, have you checked the float is still air tight? if it gets fuel inside it it won't go all the way up.
i fitted a newfloat as it had a hole :(
