mk1mexico Posted March 23, 2008 Report Posted March 23, 2008 ...and give me enthusiasm please Right iv got a week off work starting tomorrow and one ILL mk1 escort. Its also the Scotch corner meet a week today and i really want to go. I had my ST170 lump in and ready and it lunched a cam bearing on start up causing the cam to lock up, and the belt to jump, and 4 bent valves SO i stripped it and fitted a blacktop mondeo 2.0 head onto the ST block, and now theres no oil pressure (im guessing this was the cause of the first hiccup) SO iv left the car for a week because i have had enough of it. Plan is to strip it down again and find out whats going on, could be an oil pick up pipe problem or worse Anyway with a week to go im going back to it with a positive attitude wanting to get it ready (sorry GOING to get it ready!!!) for the meet next weekend. so i need cheering on
Trevmk3 Posted March 23, 2008 Report Posted March 23, 2008 you can do it mate, will be good to meet you and see your car at Scotch corner
radar tech Posted March 23, 2008 Report Posted March 23, 2008 keep the faith geezer i will be looking forward to seeing your motor next sunday at scotch corner
jed Posted March 23, 2008 Report Posted March 23, 2008 good luck mate.. shout and swear normally works for me.. oh or i give wayne a ring.
mossy Posted March 23, 2008 Report Posted March 23, 2008 Good luck matey...hope it all works out easy!
ZetecVan 2.0 Posted March 23, 2008 Report Posted March 23, 2008 Good luck with it... My oil pickup pipe came undone after getting the engine back in, so I feel your pain....
4parajon Posted March 24, 2008 Report Posted March 24, 2008 Good luck with it Graham Were all here for you mate
mk1mexico Posted March 25, 2008 Author Report Posted March 25, 2008 Well my first day off, i did nothing because i got pi55ed as a rat last night
mk1mexico Posted March 25, 2008 Author Report Posted March 25, 2008 Ok stripped it down today. No immediate obvious problem to be honest. Maybe the paper gasket is to blame?? Oh and what a bastard of a job getting the rear two sump nuts/bolts off. Used an air chisel in the end
Alan G Posted March 25, 2008 Report Posted March 25, 2008 Well my first day off, i did nothing because i got pi55ed as a rat last night Did the same... happy days!
mk1mexico Posted March 26, 2008 Author Report Posted March 26, 2008 Got my ass round to Fords this morning and ordered a new oil pick up pipe gasket, new oil pump gasket and crank oil seal. New sump gasket and sealer. Checked the part numbers and the ST170 engine has the same oil pump as a standard 2.0 blacktop zetec (i have a known good one so im going to fit that lot up tomorrow and go from there. )
mk1mexico Posted March 27, 2008 Author Report Posted March 27, 2008 Well iv spent all day today building it all up, different oil pump, new gasket, new oil pick up gasket, new sump gasket and sealer. All the suspension fitted back up on the crossmember (what a job on your own ) I took the plug leads off and cranked it but the oil light stayed on Put them back on a cranked it again and woohoo the light goes out and it runs like a fookin dream Shame about the oil pissing out from between the gearbox and sump, must have nipped the new sump gasket somewhere. I went from being happy to being sick as fook again within minutes
radar tech Posted March 27, 2008 Report Posted March 27, 2008 well done matey so you reckon i gonna meet you and see the motoron sunday at scotch corner ?? dave
mk1mexico Posted March 27, 2008 Author Report Posted March 27, 2008 Maybe mate, i need to take the gearbox out now
mk1mexico Posted March 28, 2008 Author Report Posted March 28, 2008 Gearbox out today sorted the oil leak, the sump gasket had slid into the sump about 3 inches along the rear crank oil seal face. Easy repair for a change. All back together and running sweet Just need the bonnet fitting and a seat fixing in, the scotch corner on Sunday
