Mounted mine in the boot vertical,set the pressure on the regulator to 2.5psi but on the rolling road he set it at 3psi. Runs & works brilliant :thumbsup: Mine is a 2.1 on 45s so might be different for 2.0 on i guess a 32/36 weber?
Yeah ut's a 32/36.
Same here :wink:
The pressure regulator should be as close to the carbs as possible, it's also worth changing the fuel line to 8mm :thumbsup:
