Cookie Posted May 18, 2007 Report Posted May 18, 2007 Has anyone got some measurments and pics of seat mounting bars, want to weld some into my shell before painting floors, but have no seat yet cheers
Jay_harrier Posted May 18, 2007 Report Posted May 18, 2007 Yep, I'll do some pics & measurements tomorow of mine
Cookie Posted May 18, 2007 Author Report Posted May 18, 2007 Cheers gareth for the bump And jay that would be spot on m8, be very greatful
Jay_harrier Posted May 19, 2007 Report Posted May 19, 2007 Ok, here we go: (MK2 Escort) The bars are 1 inch steel tube, no idea of the wall thickness, Reinforcing plates at either end of each bar welded to the tunnel & sill. Passenger side & drivers side exactly the same although some works cars had the passenger sat further back. The height of the bar from the floor to the centre is around 35mm but the floor contours change this depending where you measure from - pick a height & use a level I guess. The bars are roughly 520 mm long but every car is different so you'll need to tweak to fit. There's a loose nut in each seat retaining plate to bolt the seat down. Measurements are taken from the centres as shown in the pic PM me if you need more detail, I'll have a look at the works bible later incase mine is massively different. Cheers, Justin
samurai Posted May 19, 2007 Report Posted May 19, 2007 This is what im in the middle of doing at the mo,the CDS bars are 3mm thick,how thick are the renforcement plates? Yeah im makeing my own and drilling throught the bars to bolt the seats in. Thanks
Jay_harrier Posted May 19, 2007 Report Posted May 19, 2007 1.6 to 2mm plates profiled to the tubes with a channel retainer for the floating nut: Excuse the pic, the camera was having a drunken moment...
samurai Posted May 19, 2007 Report Posted May 19, 2007 Whats the measurments of the renforcement plates? 70mm x 70mm? Thanks
Jay_harrier Posted May 19, 2007 Report Posted May 19, 2007 Mine are 80W by 70H, & 1.6 to 2mm thick, but 70x70 should be fine.
Cookie Posted May 19, 2007 Author Report Posted May 19, 2007 Jay , spot on mate just what I needed gretaly appreciated, can crack on now tomorrow and make a start on them
Jay_harrier Posted May 19, 2007 Report Posted May 19, 2007 Your welcome dude , no info in the boreham book which is weird as I'm sure I've seen it somewhere. I know other people have used square section tube which is probably easier to work with as you don't have to profile the brackets so much.
