borneo Posted June 26, 2007 Report Posted June 26, 2007 Pickin up some new wheels at the weekend but I need a spare to go with them so I can sell my brooklands wheels as a complete set. Anyone got a spare or know where I might find one. Must be 25mm offset as I'll be running spacers and long studs. Is this a standard offset for any fords?
andrewg1323 Posted June 26, 2007 Report Posted June 26, 2007 Escort coswroths et25 I THink in general the pug/ford multifits come in 25 as thats a bit of a cpompramise between the two
V8ian Posted June 26, 2007 Report Posted June 26, 2007 Cosworth Seirra must be around that dimension, , So a standard sierra or mondeo may well fit
Davecara Posted June 26, 2007 Report Posted June 26, 2007 Sierra cossie is et38 or thereabouts. As said the Escort Cos is et25 and most pugs are et15, bar the 206 and the newer ones. They are et25.
borneo Posted June 27, 2007 Author Report Posted June 27, 2007 My housemate has a 306 but the wheel locates on the hub centre and not the studs (hubcentric?). Is this the same with the cossie?
Davecara Posted June 27, 2007 Report Posted June 27, 2007 All wheels should locate around the hub. Fords have a backbore of 63.4mm and you can buy little plastic spigot rings to get a pug wheel (or whatever else fits) down to that size Usually about £2.50 each for Motorworld or Halfrauds
borneo Posted June 27, 2007 Author Report Posted June 27, 2007 Cheers. I've been doing my research on hubcentric vs lugcentric setups and as you said, most cars should be hubcentric. Looks like I'm gonna have to get a cossie spare + hubcentric spacers are gonna cost me about £100 extra but hey it's gotta be done properly.
Davecara Posted June 27, 2007 Report Posted June 27, 2007 I've got a set of spacers that my G/F was using on a Pug 206 to fit ford wheels, They're about an inch wide iirc. They any good to you?
