Right....
bought this carb and manifold of twink (mainly for the manifold)
wanted to get spanner happy on it and pull it in bits but my tools are in the car and its raining so i will wait.... but i did pull apart the bits i could without them
just a few questions
Photo Sharing and Video Hosting at Photobucket
that thing on the bottom right.... what is it and should there be two of them as there was only one in the right hand barrel
Why is there 3 springs???? why not just one big one??
and below the rod with the plastic ends in the picture... the bit that looks a little rusty.... should there be a nut on the thread as it seems a little loose
the thred that is sticking out of the back of the carb before it meets the manifold.... what is it and what is missing off it???
should the throttle linkage bit be at that angle or is it wonkey???
thanks Guys :thumbsup::beer:
iv never had one of these before and iv no idea what im doing
is it worth sorting this one out or do u buy one that is rady to bolt on???
that thing on the bottom right.... what is it and should there be two of them Venturii I think, and yes, 2
Why is there 3 springs???? why not just one big one?? If one breaks you have back-up
the thred that is sticking out of the back of the carb before it meets the manifold.... what is it and what is missing off it??? A locking tab washer and a nut for both ends. That is the butterfly shaft i believe
should the throttle linkage bit be at that angle or is it wonkey??? Not sure. Does it work? If not then no it shouldn't ;) ;)
1- it is a venturi and yes you need one in each barrel
2- springs- who cares?? If one big one broke then you would have no throttle return. But you have 3 chances???
3- you could have locknuts on the threaded bar, but when fitted I doubt it would come undone on its own
4- the bit sticking out is the end of the spindle that the butterfly valves mount on. It has a washer and a nut missing.
5- linkage bent? I don't know. What am I? The Oracle or something??
1 its a veture should have 1 per choke
2 if thats the way its set up should be fine but not sure
3thats the buterfly spindle prob could do with a nylock nut on it :thumbsup:
4not sure what ur looking at :wink:
wow thanks for the multiple responses guys :lol:
does it work??? well... it open half way ok but then lower point wherer the springs are fastend to hits the plastic bit below it
it then forces the white thing to twist and pushes the end fastend to the butterfly shaft away from the carb... so if the but was on there it wouldnt be able to move and the i suppose the carb wouldnt open up i suppose :(
all the bits i need??? are they easy to get?? fairly universal bits or would it be easier to get another carb
they are really easy to get m8 as i will post them to you :wink: didnt realise they were missing will get some off one of those other carbs in the pile :mrgreen:
meant to say it will cost you 1000 iron and 5oo wood though, you can keep the clay i have shitloads :mrgreen::ykt:
PMSL :lol::lol:
people wont have a clue what we are on about
its also missing 1 idle mixture screw and the spring under it... No 56 :oops:
http://www.webcon.co.uk/weber/40dcoe.htm
idle screws are 400 clay my friend :thumbsup:
send me a pm with a list of all the bits that are missing and the numbers on that webcon picture that they relate to and i will sort them out once i have received your trade from market :thumbsup::mrgreen:
in the 4th picture there dont seem to be a choke either? . looks like its seen better day. ive got loads of bits if you need anything. that is if twinkle hasnt got the missing bits of the puzzle :thumbsup: psthere should be 2 venturis you only show 1 :huh:
the choke sits behind the aux venturi [ the bit on the right in the photo ] its barrel shapped with the size stamped on the inside lip. this should help :thumbsup:
