new brake pads...
are they sposed to be so tight on the disk?
never fitted em before but im assuming they will wear down a bit once moving, or do i need to just wear em in a bit with some sandpaper?
yeah pistons are fully home. it also looks like the disk may be touching part of the caliper :-S
bit wierd il double check it all over tomoz when im in less of a rush, iv prob made a little mistake somewhere but little mistakes can have big consequences so better make sure its right before i go sanding my pads away
calipers are mounted at the back right?
just have to check i havent got my legs on the wrong side of the car and all that :?
I used the spaces's that came in the kit. Two on the mounting bracket to leg and two for the caliper to mounting bracket. This made them sit perfectly. I can't put a pic up coz my pooter is fooked
ahh i get ya cheers! :thumbsup:
