i know u can get a piece to make 5 stud take a 4 stud wheel but can u get one to stick 5 stud wheels on a 4 tud
MK3 Zodiac hubs fit capri front legs which converts it to 5 stud, not sure how to do the back.
Its mk4 zodiac hubs you need, as yet I have not heard of using mk3 hubs. I maybe wrong
Ian
This is interesting..
What's needed to convert a rear :?:
Could some custom hubs/shafts be made up
using the Escort and Zodie shafts as a template/pattern :?:
May be intresting, you try finding a pair of Aircraft Carrier front hubs,
Rear hubs, It is often possible to redrill drums and shafts, I have done this before, goning from ford 4.25" 4 stud, to 4.25" 5 stud, but normally you have to use one of the original holes, somewhere in the garage I have a drilling Jig for doing just that, The big problem with ford shafts is the large holes for access to the bearing retainers get in the way, If you use shafts with single access holes you can get away with it, The other option is to get aftermarket shafts, I use Moser shafts from Hauser Racing, But Andy Robinson Racecars sell Strange shafts which are just as good, The other place is Quaife, but sit down before you ask the prices,
Ian :D:D
the classic ford project is suing those american style wheels on the cortina which are 5 stud
Ian :D:D
I'm interested in convertin my mk1 (eventually :roll: ) to 5 stud
Thanks for the info Ian :thumbsup:
