hi guys ive been putting a power steering pump on my rover v8d cappa . the pump is from an essex and it has the essex rack but blanked of due to the previous owner not liking power steering .basicaly its all there adapted braket etc and the pump will sit at the bottom of the bay . anyway cut a long story short i dont know what belt to use or can i get someone to make one up . also on the engine to get the belt aroung the bottom pulleys it looks like i will have to take the pulleys of is this corretc or does someone no a trick or two .
and if i can get a belt made how do i acurately measure what size i need . can some1 confirm it is a power rack
has anyone else got pics of there v8 power steering setup :rolleyes:
does anyone have a diagram of a v6 essex power pump setup so i can see wer thepipes go .
SORRY IF I SOUND LIKE A GORMLESS BAR STEWARD .
cheers guys .
_________________
Honda Valkyrie
I'm sure you'll find a belt off the shelf. If you cut a belt and glue the ends together at the right length and post it to Apollo Bearings 01293 539 539 they'll match it and post you one. The belts are available with a different v angle so send them the right one. :thumbsup:
Finding a belt shouldnt be a problem mate, Take a Piece sting and run it like you would the belt. Mark it / Cut it whatever, measure it in MM then bob down you local motorfactors, Ask what they have in around that size and buy a couple of diffrent sizes. Just take into account the width of the pully or just take your pully with you to check the width while your there. :thumbsup:
