BronzeRS Posted March 13, 2008 Report Posted March 13, 2008 Those non magnetic bits next to the coin look suspiciously like the bits of head gasket I am missing from mine??
Jimbob-Squarepants © Posted March 13, 2008 Report Posted March 13, 2008 Sorry to hear this Mr. H. As you know, my one was a difficult birth with it's fair share of problems. I remember you asking me about turning the crank over by hand. If it was turning like you said it was, I doubt that metal is from big/main shells. For that to happen, that crank would have been absolutley solid. How did you fit the cam bearings mate? As you know, I tried to do mine, but I couldn't slide the cam in. Once it was in, I tried to move it with some force and guess what happened.... the cam bearings lifted and spat out metal like you have there. In the end I took my block to Burtons for them to fit the bearings. Once back, I could slide the cam in with no force, and I could spin it by my fingers. All it takes is one bearing to be slightly offset by a thousand of an inch and the thing wont turn. Chin up son, you will get there. If you want some therapy, PM me
johnny_h Posted March 13, 2008 Author Report Posted March 13, 2008 Hi Jim, I didn't replace the cam bearings as I was using the same A2 and followers that were in it before.
johnny_h Posted March 13, 2008 Author Report Posted March 13, 2008 Trying to find out what caused the lack of oil pressure I took out the pump to check clearances and found this. Is this normal?
Rich Sav Posted March 13, 2008 Report Posted March 13, 2008 i dont think so mate have u tryed spinnin the shaft in the pump if its not smooth the oil pump is prob fooked which should explaine the lack of pressure
johnny_h Posted March 13, 2008 Author Report Posted March 13, 2008 The shaft turns ok now it's out and emptied of oil.
Col-ashtonmobile Posted March 13, 2008 Report Posted March 13, 2008 piston,s at fault should not cause loss of oil pressure , wrong mains comes to mind , best get it checked mate thoroughly mate
