I run my bcf2 cam on standard timing gear, its only a mild cam but using the duplex you could time it spot on, personally i wouldnt bother, if you wanted to run a 234 or hotter cam then its worth it :thumbsup:
Same here. I am running an A2 cam on standard timing gear with the use of an offset dowel to time the cam in. I doubt I will go Vernier, but I may upgrade to a Duplex chain and sprockets at a later date.
i might be missing the point here but the picture shows a cvh/pinto overhead cam pulley. but the xflow used a side cam with a chain drive suirely this can not be converted to a belt as it is lubricated !?!?!?!? :?.................................*picture is just an example* :oops: looks like i didn't read properly :oops:
