mossy Posted June 10, 2008 Report Posted June 10, 2008 Everything is disconected from the gearbox, speedo, clutch cable, bellhousing bolts, centre mount.... but it still wont come out! the cars fallen on me twice from shaking it so much to get it out, but it wont budge! anyone got any ideas?
Tom Posted June 10, 2008 Report Posted June 10, 2008 you sure you've got them all out? prop off? starter out?
mossy Posted June 10, 2008 Author Report Posted June 10, 2008 yup, starter, prop, gearstick, mounts, bolts....i can near enough spin the box about 360deg in the tunnel....its off about 2cm but wont come any further
Tom Posted June 10, 2008 Report Posted June 10, 2008 prop just the spigot stuck in the drive plate mate, it'll come out
zetecmk2 Posted June 10, 2008 Report Posted June 10, 2008 why not do it at my place tomorrow? be round with truck about 6 hopefully
mossy Posted June 10, 2008 Author Report Posted June 10, 2008 why not do it at my place tomorrow? be round with truck about 6 hopefully just wanted one less job to do tomorrow really! Is your welder mate going to be about to have a look at my rear tubs too?
Toby Posted June 10, 2008 Report Posted June 10, 2008 Not an escort man but it might be getting out of line as you go backwards with it - on mine you have to gently jack the front of the engine up to get the rear of the box to tilt down and out of line with a bit of chassis that it wont come passed, it feels like it gets stuck then too. I have also done the leaving the starter one in!!
bortaf Posted June 10, 2008 Report Posted June 10, 2008 deffo not left the 10mm dust plate bolt in? i allways forget that one
Smudger105e Posted June 11, 2008 Report Posted June 11, 2008 Like Toby says, sounds like it's not in line engine---box
zetecmk2 Posted June 11, 2008 Report Posted June 11, 2008 it was the sump hitting the crossmember so not letting the bellhousing clear the tunnel! out now if mossy remembers the sump tomorrow, we should have the pinto in!! (with a bit of help from the air-saw)
mossy Posted June 12, 2008 Author Report Posted June 12, 2008 yes twat face here forgot the ally sump to swap over...another problem, ive got no gasket!
cisco24uk Posted June 12, 2008 Report Posted June 12, 2008 Stick a bit of silicon round it thats what most modern cars use. Is the release bearing stuck on the shaft spline?
