Why do none of the cheaper companies such as Hadrian make these panels? There are plenty of mk1 rear panels around but you can only seem to get the rear valence for the mk2....weird! Pisses me right off it does!
yeah that's the only part i can seem to find... the issue i'm raising is that, aside from companies such as expressed panels, no one makes pattern replacement rear panels for the mk2, but they do for the mk1. that tiny valence panel that antz found is as much as you can get in terms of a fabrication rear mk2 panel.
