Hi guys-I have the capri booked into sanspeed on friday but before it goes i have a 3-piece large bore manifold to fit (pinto), the trouble is it needs a bit of cutting and shutting to fit (it fouls on steering coupling).
So does anyone know if there is anyone near me that can help out??
Would like to fit it cos i think its gonna make a big difference to the power figures also AFR.
any help is greatly appreciated.
These are a pig to fit and the people that happily sell you them will rarely tell you just how much modifying you need to do to get it in.
I can't help with a capri installation but know that if fouls the engine mounts when fitted to an escort, have you checked it clears your engine mounts?
yeah-i fitted it all up and it only fouled the steering joint-fitted great otherwise
do you know if i can change the steering joint for a smaller one???
