Retro-gone. Posted August 10, 2008 Report Posted August 10, 2008 on pinto , how do i remove it from the water pump? and am i ok to fit the fixed fan from my 1600 on to the 2.0?
antz Posted August 10, 2008 Report Posted August 10, 2008 take off the original and fit a electric fan. takes the strain off the engine and will give you a small boost in bhp
Retro-gone. Posted August 10, 2008 Author Report Posted August 10, 2008 ya see antz your cleverer than you give yourself credit for, now what the fecks an electric fan
antz Posted August 10, 2008 Report Posted August 10, 2008 all modern cars have one i think. on your pinto itll have a fan that is driven by the engine from the pulley. This runs constantly and puts pressure on the engien to spin the blades. an electric fan can be fitted in front or behind your radiator and works by electricity and will kick in t a desired temperature which you set it at. they are more reliable i think and you can tell it when you want it to run instead of it runnign when it wants. look at pages 59 and 60 of your burtons catalogue they arent cheap and the power gain will be in the single figures but every little helps and i prefer them
Retro-gone. Posted August 10, 2008 Author Report Posted August 10, 2008 nah im not bothered with that mate, i just wanna seperate the fan from the pump to fit a new pump.
antz Posted August 10, 2008 Report Posted August 10, 2008 i gathered that but im just thinking about saving you putting the fan back on
5hane Posted August 10, 2008 Report Posted August 10, 2008 takes the strain off the engine and will give you a small boost in bhp beem told up to 8 bhp
Col-ashtonmobile Posted August 10, 2008 Report Posted August 10, 2008 undo the big nut behind the fan , wedge a screwdriver in between the four small bolts that hold the pulley on then undo the big nut , and it,s a left hand thread , hope this helps
Retro-gone. Posted August 10, 2008 Author Report Posted August 10, 2008 bugger, havent got a spanner big enuf
bortaf Posted August 10, 2008 Report Posted August 10, 2008 you need a special snanner or just use a sharp screwdriver or chisel to tap it off, fiiting a fixed fan will loose you around 4BHP over a viscouse one, leccy will only gain you 1 or 2 BHP at the most over a viscouse and only when off, when on the drain on the alt will cancle out any gains over the viscouse but as they are hardly on they are better, the trouble is where to put the switch on a pinto
caprinerd Posted August 10, 2008 Report Posted August 10, 2008 remember the viscos fan runs a reverse thread so undo by turning as if tightening
evil knievel Posted August 10, 2008 Report Posted August 10, 2008 use an oil filter spanner to stop the pulley from turning, (wrap it round then lock it in place, with it resting on the radiator hose connector bit to keep it taught) then get the correct spanner (10mm or 13mm, i dont remember) and undo the four small bolts on the back of the pulley. then hold the big bolt to stop the water pump from turning and spin the fan anti clockwise, should pop right off. IF NOT undo the water pump and get that bugger off with a vice!
Retro-gone. Posted August 10, 2008 Author Report Posted August 10, 2008 to be honest i think il use the fixed fan off my 1600 cos its yellow, i cant see that losing 4bph is gonna be noticable?
evil knievel Posted August 10, 2008 Report Posted August 10, 2008 well if you're not bothered i suppose it doesn't matter... why not paint the viscous yellow? have you got the fan off yet?
Retro-gone. Posted August 10, 2008 Author Report Posted August 10, 2008 no its not off yet, it can stay on cos im using the other one.
evil knievel Posted August 10, 2008 Report Posted August 10, 2008 you are replacing the water pump then? fair enough mate best of luck
Retro-gone. Posted August 10, 2008 Author Report Posted August 10, 2008 yeah replacing the pump, in fact replacing everything that i can, im building a 2.0 to put in my mk1 to replace the stock 1600.
evil knievel Posted August 10, 2008 Report Posted August 10, 2008 i've got first dibbs on any spare bits then if you're selling them of course.
