Very easy to convert :mrgreen: heres my ones
In this pic the spring seat is on the bottom upside down,luckily didnt weld it up properly before we noticed :oops:
The right way up :lol:
All done
Easy to adjust while on the car,you can buy a special spanner for the job :wink: only a few quid :thumbsup:
I've done this too and the most difficult part was cutting the original spring pan off.
They're only brazed on so if you have access to a gas torch you can melt the braze and tap them off with a hammer.
The other way is to cut most of them off with a cutting disc and then carefully grind off the remaining steel ring.HTH.
The kit plus springs and bump stops.
Welded on
Finished and painted.
This is the way i done mine but these are not my pics :wink:
Cut all the way round with a hacksaw,you can then knock the cup off with a hammer and grind the rest away,you'll know when your through as the metal fileing will turn to rusty fileings once your throught the cup :mrgreen:
Always wondered how you decide how far up or down the casing you weld the threaded tube?
The strut body has an internal thread right at the top to take the insert so I made sure the coilover threaded tube was below this so that I could weld it on without damaging the internal thread.
Don't know if there are other reasons but that's what I did.hth.
i rang graeme at gs escorts today, springs are £22 each and the rest of the kit is £50, thats the cheapest i can find anywhere so im getting mine from him, just to add... hes a good bloke, doesnt mind you picking his brain like some dealers do :thumbsup:
the threaded tube only needs welding at the bottom i heard
so no problems with danger of damaging internal thread
Yeah,I heard that as well but when it came to welding them on my own struts I decided to put a few decent tacks around the top.Better safe than sorry. :wink:
i read a classic ford last night , feature on fitting coilover kits, says you can tack the top end if if makes ya feel happier, theres a lot of stress/weight goin on there so i think il be welding tops and bottoms too.
all down to feeling safe i guess.
  • 2 weeks later...
got mine today , what i want to know is why there is 2 of the threaded round adjusterers on each leg/thread, 1 of them sits under the spring but what abouit the other one?
the kit very luvlee tho 8)
One's the spring seat and the other is the locking ring that you do up with a C-spanner . :thumbsup:
Must type faster. :D
:x the bloke doing mine still hasnt started (what i know) :x:lol:
would have been easyer fo me to learn how to weald ! :lol:
cant complain really, hes well alright and im not in a rush :lol::(
yay for me
i normally get beaten to the answer
