Hi all, i have a new engine and a new Clarke engine stand so i can paint it etc.
How do you all mount it? the brackets that are supplied arent long enough to bolt onto the bellhousing holes with the clutch/flywheel assembly there and it looks as though it will still be too short with the clutch off?
Also, i'll need some LONG bolts!!
:thumbsup:
Yep, you have to remove the flywheel. To mount my engines I use 4 lengths of studding which I secure to the arms first with a nut either side, then I plonk the engine in and secure that with another set of nuts. It makes mounting and removing the engine easier as the studding can't fall out :thumbsup:
alternativly, find a old engine mount, cut the rubber off and securely weld a stub that fits the engine stand bore to it, that way you can have a side mounted engine
Great stuff lads, Cheers!
I'd better get my arse donw to the local hardware shop for some longer bolts etc. :thumbsup:
