hi guys as mos tof youy know i was having issues at CF show with my car not running right and i replaced most of the ignition system at the show then the coil died on the way out and had to wait for the aa
so the car has had a new coil condensor rotor arm dizzy cap set of points plugs and leads
onc ei replaced the coil and condensor the car ran lovely for a few days but now theres a missfire it wont rev evenly sometimes will cut out when i put my foot down other times will rev really undevenly cant hold it at any revs it seeks up and down so trying to hold it at 2k ittl hunt between 500 rpm and 3500 rpm .... or just cut out ... i cant work it out
i need to get it sorted asap really its going into my mechanic later but any ideas you guys have would be appreciated
i did have an air leak but im fairly sure its fixed so unless its another one ...
took it up the garage and he reckons its deffo a fuel issue so suggested repalcing the carb
